  1. I'm looking into buying a dvd burner and i'm wondering if it is possible to put multiple vcd movies on a dvd-r or dvd+r but I would like to know if it would be possible also to put the movies on the disc but have a main menu to choose which movie you would like to view? Any help would be greatly appreciated.
    don't hang your dirty laundry in public
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Yes these things are possible, however you may want to start simple and work your way up from there. DVD authoring can often involve alot more then VCD or SVCD if you try to get fancy. But as I said before YES what you ask is technically possible.
    Apr 2002
    Ireland
    did you check out this guide?
    https://www.videohelp.com/vcddvdr.htm
  4. Thank you for the help....and the guid helped alot too...
