I am using dvd2one and IC7 for movies up to 6.5GB with great success. I may even go larger to dodge having to split a movie.
However, the Sopranos has 4 episodes on each disk therefore approx 4 hours. About 8gb, to much for one disk. Is there an easy way to get 2 episodes onto each of 2 disks. Neither of the above programs will allow me to just select 2 episodes. I have looked at ifoedit, and then put it away again.
There must be an easy way?? Could ripped (dvddecryter) vob files be put into an authoring package and burnt with home made menus??
What do other people do??
P.S I do want to keep the 5.1 audio (just the one channel, no subtitles)
Results 1 to 11 of 11
Do a SEARCH on Sopranos.
Its been done to death.
https://www.videohelp.com/forum/viewtopic.php?t=149586&highlight=sopranos
VidHack -
Just run the VOBs through DVD2AVI and take those to TMPGE. Source clip out each episode to MPEG-2 and burn with the software of your choice. TMPGE stage will take a long time, but that is my best suggestion.
Nah. I used DVDDecryptor and ripped each ep. Just re-authour 2 eps/DVDR. It's not worth re-encdoing unless you are so broke as to save a few bucks on blank media.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
This is what I do...
use "dvd decrypter" to copy or rip the dvd as an "ISO" to the hard drive.
use "ISO BUSTER" to "extract the "video_ts" directory from the "ISO"
use dvd2one (latest version) to convert the files in the "video_ts" directory to an "appropriate" size so that it can be burnt
use "nero" or "record now" to burnt
(total time should take no more than two hours for all of these steps) -
Thank you all for your input.
Gazorgan, do you rip each episode separately? What do you use to re-author? Do you have to re-encode? Does the authoring package accept the vobs from dvddecrypter? Do you use the IFO’s .
Dbaker6165, are you producing a single DVD with 4 episodes? Or 2 disks? -
well i have tried this with band of brothers and other dvd's with menus... EVERYTHING is the same as the origional dvd (as far as option, some may argue quality but screw them I watch tv 2 yards from the tv haha)
yes... I produced a single dvd of band of brothers disc one which has two episodes on it! Follow my directions! or try variations of my directions (meaning make up your own way, I did).
I have a dvd with 6 episodes of the office,,(comedy) on it ,,half hour each,,,total of 3 hours,,aint been having any joy copying it,,,i can only get 1 episode at a time,,,any brainy clever folk wanna share the wisdom of how to putting all 6 episodes on 1 dvd,,,,,,,,
I did the sopranos using the older version DVD2one and put the whole disk on one dvdr. I didn't notice any quality issues with it.
I have backed-up all the sopranos sets, and I notice minimal loss with season 2&3 when using IC7. Season 1 is very pixelated, but probably from using a low-quality camera/encoder when putting it on dvd and having alot of noise.
"Mustard?! Don't lets be silly now. But lemon, thats different, thats nice." - The Mad Hatter
Put 4 Sopranos episodes from 2 DVD5 to 1 DVD9
By audax in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2012, 01:23 -
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Student needs help adding subtitles to Sopranos without converting
By Dains11 in forum SubtitleReplies: 12Last Post: 28th Aug 2009, 09:15 -
episode dvd disk
By DSLGuy in forum Video ConversionReplies: 2Last Post: 14th Oct 2007, 20:09
