  1. When using TMPGEnc ver 2.58 encoding avi to pal svcd, i have been receiving stream error 28% into progress. the film is very high quality divx. Can anyone help me?
    Manchester, England.
    I'm not sure what to recommend here Ian, hopefully this bump will bring some help.
    Mar 2002
    canada
    sounds like bad frames. try this: https://www.videohelp.com/forum/viewtopic.php?t=142555
    :P
    ontario ,canada
    If it happens at the same spot every time,it's likely a bad frame in the video as per the previuous poster.It happened to me once also.Cut out the frame,or make another avi.It worked for me.
    bmiller,ont.canada
