Each time I try multipass VBR with a particular AVI I get an error that says video check sum different from that of previous pass and source data or time code may be different. Any suggestions as to what might be going on. I will include a copy of the Avisynth script and the log file:
Thanks in advance,
VC
LoadPlugin("C:\Program Files\DVD2SVCD\MPEG2Dec\MPEG2DEC2.dll")
avisource("pinb.avi")
BicubicResize(720,352,0,0.6)
AddBorders(0,64,0,64)
ConvertToYUY2()
ResampleAudio(44100)
***** Cinema Craft Encoder SP started at 2003/03/25 23:24:45 *****
SDK version 2.50 (built at Aug 17 2000 21:02:49)
fexp thread created.
fexp thread terminated.
***** Cinema Craft Encoder SP shutting down at 2003/03/25 23:25:05 *****
***** Cinema Craft Encoder SP started at 2003/03/25 23:25:20 *****
***** Cinema Craft Encoder SP shutting down at 2003/03/25 23:25:34 *****
***** Cinema Craft Encoder SP started at 2003/03/25 23:25:42 *****
***** Cinema Craft Encoder SP shutting down at 2003/03/25 23:25:58 *****
***** Cinema Craft Encoder SP started at 2003/03/25 23:26:15 *****
uncompressed YUY2.
cce created.
encoder initialized.
encoding started at 2003/03/25 23:34:50.
>> received encoding start notification
>> received encoding stop notification
encoding stopped at 2003/03/26 00:47:14.
sync stopped.
fdev0 closed.
fdev1 closed.
>>>> Performance <<<<
Source : 5026.833 seconds (120644 frames)
Elapsed: 4343.578 seconds
>> File reading 2593.459 59.708 %
>> Decoding 0.000 0.000 %
>> RGB -> YUY2 190.534 4.387 %
>> MPEG encoding 1559.585 35.906 %
uncompressed YUY2.
cce created.
encoding started at 2003/03/26 00:47:22.
encoding stopped at 2003/03/26 01:23:26.
cce encoding failed: Error: Video check-sum is different from that of previous pass.
Source video data or time code may be different
Please check video tape or the information file
--- information ----
Current: check sum = 01b3e15f
Previous: check sum = 01b7451d
sync stopped.
fdev0 closed.
fdev1 closed.
uncompressed YUY2.
cce created.
encoding started at 2003/03/26 07:38:12.
encoding stopped at 2003/03/26 08:50:45.
sync stopped.
fdev0 closed.
fdev1 closed.
uncompressed YUY2.
cce created.
encoding started at 2003/03/26 08:50:48.
encoding stopped at 2003/03/26 09:27:24.
Current: check sum = 01b3dcd0
sync stopped.
fdev0 closed.
fdev1 closed.
uncompressed YUY2.
cce created.
encoding started at 2003/03/26 21:46:48.
This is so much fun!
http://forum.doom9.org/showthread.php?s=&threadid=21859
Read Question 27. -
Thanks for the tip. I always think my problems are so unique. I guess i'm not so special after all.
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 08:46 -
How to Convert AVI to DVD + AC3 with CCE and AC3Machine
By ta2 in forum User guidesReplies: 40Last Post: 21st Jan 2010, 19:01 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 06:46
