Ok I finally got TMPGEnc to work without giving me a wierd module error every 30 mins. Now that I encoded it(looks great by the way), it's around 2 gigs per 45 mins. How do i go about trying to fit 4 of these 45 min chunks on a dvd movie when clearly they will be over the limit? Thanks
Try using a bitrate calculator, there are several in the tools section, the adjust the encoders bitrate accordingly.
The size of an mpeg file is determined by just two things, bitrate and movie length, thats all you need to worry about in this respect. If using VBR encoding a bitrate calculator will tell you what Average bitrate is needed.
Question about Firewire>USB (Same end result)?
By sj022698 in forum Capturing and VCRReplies: 1Last Post: 24th Apr 2011, 23:37 -
Does a middle encode harm the quality of the end result?
By PuzZLeR in forum Newbie / General discussionsReplies: 8Last Post: 21st Jul 2009, 19:26 -
Burn DVD using DVDFab end result one file in iTunes?
By Kramer620 in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:26 -
Megui, some problems withe encoded result
By boy69 in forum Blu-ray RippingReplies: 6Last Post: 30th Sep 2008, 17:16 -
how can i get stable end product
By mrgain in forum EditingReplies: 7Last Post: 9th Jun 2007, 02:38
