hi there, im a newbie to making vcd's, i downloaded a couple movies off kazza and found that when i burned them onto vcd they movie had been squished alittle, so i wanted to make widescreen vcd's is there a way i can do that????????????
yes. if its supposed to be widescreen.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
the search button is your best friend. it won't hurt you. this has been talked about several hundred times.
Select Other Settings
Click on Advanced
Change the Video arrange Method to Full screen (keep aspect ratio) if you wan't the movie to look exact the same as the video source.
If you have a widescreen movie and you want it to be fullscreen(no borders) select instead No margin(keep aspect ratio) and TMPGenc will cut it.
I suggest you read the whole guide
https://www.videohelp.com/tmpgenc.htm
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
Make Widescreen HD into Fullscreen like my blu ray player does
By PSS2 in forum Video ConversionReplies: 8Last Post: 22nd Mar 2011, 03:04 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Encoding 16:9 Widescreen MKV using CCCP pack and CCE results in 4:3 MPEG 2
By octagon69 in forum Video ConversionReplies: 21Last Post: 17th Oct 2008, 21:52 -
Cutting 4:3 Top & Bottom, to make 16:9 Widescreen
By bibi in forum Newbie / General discussionsReplies: 3Last Post: 12th Jul 2007, 23:48
