Has anyone tried taking a DRX500UL out of its case and installing it as an internal drive? I have seen postings stating that the DRX500UL identifies itself as a DRU500A. Is the DRX500UL simply a DRU500A drive installed into an external case?
Ok i believe i am right here but the ul version internal parts that make the sony ax the sony ax are their and why would you need to write a whole new firmware for just making something external so that is why it says such. You can't make it internal cause the external is just a smaller internal but without things like ide connectors and a shell. The thing wont fit into your drive bays so their is no chance of it working sorry
Just wondering if you have seen one taken apart, or are you speculating as to what might be inside? As a counterpoint, I can see a financial incentive for Sony to produce just one drive, and put some of them into an external case and sell them at a premium.
As psychoace stated external drives are mechanically different as there is no 5.25"case to mount in your tower and the connections are hardwired. Buy a DRU-500AX that way you have the internal/external option.
BTW...I have my Sony in an external enclosure via firewire. -
Well I had a sony firewire cdrw the 8X speed drive and the drive quit working after 1.7 years and I bought an internal lite-on 12X and put it in the case and it worked fine.
The external drive is just the internal drive stuck in a firewire enclosure also there are no real internal firewire bridges on motherboards for most computers and there are no internal firewire devices.
I am sure that you could make the external drive internal with no problem
I took the internal drive and put it into a firewire case with no problem
I am pretty sure that there would be no firmaware issues
Looking for best 2tb internal drive and dock
By neworldman in forum ComputerReplies: 3Last Post: 25th Nov 2010, 05:14 -
What will I need to add a 1TB internal hard drive to my PC?
By Captain Satellite in forum ComputerReplies: 12Last Post: 9th Dec 2008, 10:17 -
Videos stutter from internal drive, but okay off external drive
By ruggrock in forum Software PlayingReplies: 7Last Post: 22nd Jan 2008, 14:17 -
Internal drive Pioneer 18 x versus Philips 20 x
By coody in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Oct 2007, 14:31 -
internal hard drive
By LFC 1304 in forum ComputerReplies: 3Last Post: 4th Jun 2007, 12:37
