Im able to do this with Unlead but i would like to know how to do it with Nero.It just tells me to put in a bigger medium but i know i can fit it on there.
Maybe i need to make the mpg a image file first ,in which case can somebody please recomend a proggie for that.
thankx for help
When using Nero to burn the MPG make sure that you select the VCD or SVCD project type (depending on your MPG type), otherwise you will just be burning a data CD (700mb max) not a video CD (800mb).
If you still want to try the image approach, you can use VCDEasy. -
yep i recommend you get VDC easy
free and ezy
does all the trix
add the mpeg file
add chapters if you want
then HIT GO!!!
ezy as!
have fun
oh yeah before i go, i make my mpeg on TMPG as much as 795mb
and it burns ok on VCD easy
How do I make a 700MB+ video file to a 700MB video file?
By riahc3 in forum Newbie / General discussionsReplies: 26Last Post: 2nd Jul 2009, 20:55 -
Req. .rv to .wmv converter or .rv player
By naufil in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2009, 04:20 -
Req: Software For A Faster Pc Start
By Teac23 in forum ComputerReplies: 8Last Post: 14th Jan 2009, 09:46 -
Need help burning a 700mb file onto a disc to be played on DVD player
By chaoscreater in forum Video ConversionReplies: 7Last Post: 11th Jul 2008, 04:20 -
REQ : - SOUND Distorted from footage
By mojoeuk in forum EditingReplies: 2Last Post: 23rd Nov 2007, 14:54
