I am getting the following "The owner SID on a per user subscription doesn't exist" error using InstantCopy.
Searching the threads, they mention something about either the remote desktop causing the problem or some audio difficulties. I do not ever use the remote desktop so I do not know what it is about. How do I go about fixing this problem? Thanks...
Yes, I have the latest version. And I have successfully backed up a dozen DVD using InstantCopy so I am fairly sure that I know the correct procedures in using InstantCopy. However, since yesterday, I cannot use InstantCopy without the above error message appearing....CAN ANYONE HELP PLEASE???
sounds like you either have a pirated copy "shame shame" or someone pirated your copy and rendered your copy useless as long as you are connected to the internet
try disabling your internet connection and then use the program -
The SID is associated with W2K or XP Security Identifier. Did you rename, delete or change USERS on your computer? This problem could also occur because you did something to the REGISTERY.Originally Posted by dckim64
jarvis1781,
You are wrong since it has nothing to do with an internet connection. I found out from an old historical thread that this error was encountered before and it involves the monitor setting. I accidentally changed the monitor setting to 16 bits and a simple matter of resetting the monitor setting back to 32 bits fixed the problem. It is now working fine. Please refrain from accusing someone of having a pirated copy until you are actually sure of it.
Frustrated Sony HDR-SR12 Owner
By jehill in forum Newbie / General discussionsReplies: 20Last Post: 5th Jul 2009, 04:54 -
I'm now a PC owner
By tgpo in forum Off topicReplies: 17Last Post: 9th Feb 2009, 04:46 -
Pissed off Ipod Touch owner needs to vent
By ryangarfield in forum Off topicReplies: 10Last Post: 23rd Sep 2008, 15:41 -
New HDV cam owner, quick question.
By shadablade in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd May 2008, 00:17 -
Owner's Manual
By golfnut in forum DVD & Blu-ray PlayersReplies: 4Last Post: 17th Jun 2007, 12:37
