Hey I was wondering if anyone can give me some info on the Advent 7012 laptop computer. I just bought it as PC World so I can copy my DVDs quicker. It has the P-4 2.6 processor. My question is, why the hell does the fan always stay on? I've only owned/used 2 other laptops before (Fujitsu-Siemens Amilo 1.0GHz Celeron and FS Lifebook 1.4 P4) and the fans only kick in during high demand processing, like when using TMPGEnc. Yes i bought this computer to speed up my burning processes, but when I actually do use it for normal work, the constant drone of the fan is going to cause me to chuck myself in front of a Southwest train! I know these may be dumb questions, but is there way to change the fan seetings? Do i *really* want to, ie will it harm the computer? Do Advent computers suck? Any suggestions of better-for-my-money laptops?
Thanks in advance. I can be reached by email at brennan_macdougall@hotmail as well.
Any information is worth its weight in gold!
it is perfectly normal.. but if i were , i would get the Centrino processors that came out. You can go with them to 8 hours, thats way better for encodes..
But down to the facts...
the faster a processor is clocked..(Mhz/Ghz) the more heat it produces. Especially a 2.6 P4. the 1.4 may not produce much heat but as speed gets higher, you get more heat comming out so thats why the the fans run faster.
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
advent Ht3061a manual?
By mvp in forum Off topicReplies: 0Last Post: 16th Dec 2008, 15:43 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56 -
advent dvr510
By stragr in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th May 2008, 16:10
