I'm pretty new to creating covers for dvd's now so please bear with me....
I'm looking to get a program or something to help me create covers for my DVD cases. Now a lot of programs say CD/DVD jewelcase creators but don't a lot of people consider the square jewel cases DVD cases ALSO?
So how would I know if they mean it will create standard DVD case covers or just the regular square covers?
Another thing, I have these dvd cases that are clear & come in 2 pieces that you snap together but there is no way to put a cover on the outside of case unless you stick it there somehow & that's awful....or put it on the inside which doesn't fit so well but there are little place holders...is this only for booklets/pamphlets or something & no way to use actual covers on these cases??
Is the only way to use a DVD insert is to stick it into a pocket on the actual DVD case? and if it has none then I am outta luck?
Results 1 to 16 of 16
Not exactly. Let's take this one step at a time:
Next:Another thing, I have these dvd cases that are clear & come in 2 pieces that you snap together but there is no way to put a cover on the outside of case unless you stick it there somehow & that's awful....or put it on the inside which doesn't fit so well but there are little place holders...is this only for booklets/pamphlets or something & no way to use actual covers on these cases??
Anyway, click here to look at most of the suggested labels and program I mentioned.Hello. -
for software get neato's media face. as for the covers go to www.cdcovers.cc
I use CoverXP to create DVD Covers...You can use it for a variety of different kinds of covers. There is both a free version and a paid version. The primary advantage of the paid version is that it lets you put overlays (text or images) on top of the initial image you load into the cover field. Here is a link: www.coverxp.com
If you are familiar with Photoshop you can find many templates for cd covers & dvd covers by doing a search on google!
Originally Posted by coda304
Thanx Tommy and everyone..
I will check out all those programs and links....THANK U! -
I use a combination of Photoshop and Illustrator for my DVD covers. Suggest you work in minimum of 150dpi (CMYK of course) for covers printed on inkjets, higher if you've got a good laser printer. I use DVDcoverart.com for ideas (especially when I turned my Star Wars VCD set to DVD). You can also find templates as well as typical video icons (DVD video, THX, studio logos, etc.) there.
IMO the biggest part of the cover creation is the print. Use a good laser printer if you want it to look nice. Glossy paper is bollocks; if you're inserting it inside the plastic sleeve for the cover you'll never tell it's glossy anyway. For inserts maybe use a light text gloss. -
Start by making the front and back separately which should each be 1535x2175 pixels.
Then make the spine which should be 170x2175 pixels. Then put all three together for a total of 3240x2175.
Photoshop is the best. Also no less than 300dpi. -
I use CoverXP for my DVD Cases but they are alot of the times too short and uneven, does anybody know the right dimensions I should put???
Originally Posted by BiggNewt
Under NeroExpress there is a label maker. This has the appropriate template that you can use for DVD cases as well as others. I get my DVD case images from http://www.cdcovers.cc/.
Goodluck! -
A newbie...is it safe to put a label on a DVD disc itself, just like you would a CD. won't it affect the playing in a DVD player?
Originally Posted by gee69
I gave up labelling them anyway - Just couldn't be bothered!
I think it depends on:-
a) DVD player
b) Media
c) labels
d) application method
e) phase of the moon. -
I created the DVD cover case myself using MS Word, PhotoEditor and an color ink jet printer.
Once I got the size right (by measuring the case itself), the rest is simply an art design work (which involves lot of creativity).
After printing on regular 8.5x11 paper, I cut the edges to get the correct size then slide that in. Easy.ktnwin - PATIENCE
DVD Covers - What Paper?
By Nitro89 in forum MediaReplies: 12Last Post: 15th Apr 2009, 18:02 -
DVD covers
By Seasonal in forum Off topicReplies: 3Last Post: 3rd Mar 2008, 18:30 -
DVD Covers
By Beefer in forum MacReplies: 7Last Post: 15th Nov 2007, 14:17 -
dvd covers sizes
By ssaamm in forum Newbie / General discussionsReplies: 7Last Post: 14th Nov 2007, 17:59 -
HQ DVD Covers Before There Release
By twiggy99 in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2007, 14:01
