I have a problem with dvd'd encoded with cce when I create the dvd or even multiplex th audio+video I have sync problems.
My source avi file is in perfect sync and is 40 minutes and 26 seconds
My encoded audio is 40 minutes and 26 seconds
My encoded video is 40 minutes and 23 seconds
To see if the problem was related only to that file I used another show at 41 minutes 12 seconds but ended up with the same problem audio fine but video 3 seconds short
What is also strange is that no beginning or end video is missing from the encoded files
Source settings
Video: Picvideo mjpeg 720x480 @ 29.97fps
Audio: 44100Hz 16 bit mono *annoying sound card line-in is only mono
CCE settings
4300 bitrate with dvd compliant checked
audio converted to 4800hz joint stereo
Plus virtualdub reported no frames dropped during capture so the video should not of been just squished
Read this thread. It may help.
https://www.videohelp.com/forum/viewtopic.php?t=147885Impossible to see the future is. The Dark Side clouds everything...
Removing the first 18 seconds of a video
By Simmons in forum Video ConversionReplies: 9Last Post: 14th Jun 2011, 06:18 -
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 23:14 -
Converting a 480x720 2:3 short to a 1280x720 16:9 HD short.
By Cyrax9 in forum MacReplies: 2Last Post: 14th Feb 2011, 17:40 -
Some DVD authoring programs will not accept CCE encoded mpeg2 files
By ettin in forum Authoring (DVD)Replies: 8Last Post: 18th Jun 2008, 15:57 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 16:37
