Is there a way I can add some kind of copyright protection to my burned back-up DVD-R copies, so they can not be copied?
Not in any realistic way. If Hollywood cant do it then I doubt the layperson has any way to do it.
If people want to break the code badly enough they will. -
The commercial ones you backed up had copyright protection, did it help?
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I have had good success with this method.
1) Take your backup and grasp in one hand, with the "business" side up.
2) Take your car keys, and drag across, making a deep furrow from the inner rim to the outer rim.
3) Dust off the plastic bits from the surface.
4) Done!
Using my method, I haven't had anyone successfully make a copy when I have loaned them out! -
If you author with Maestro you can turn on Macrovision, and CCE, but one must ask why? Look what good it obviously did.
SeanWe all like Sheep have gone astray...
Copyright and Child Protection when videoing
By IKnowNothing in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2011, 09:23 -
Adding 'copyright' info to video clip in Ulead DVD Moviefactory 6
By colinb1 in forum EditingReplies: 3Last Post: 19th Apr 2011, 07:13 -
Panasonic DMR ES20 . copyright protection? CPRM? FR mode no pause etc
By texas1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 2nd Mar 2008, 13:10 -
key exchange for dvd copyright protection
By repeatrepeat in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2007, 23:54 -
VHS Copyright protection
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2007, 05:57
