I have been encoding episodes of a tv show from avi to mpg in order to burn them to VCD, needless to say with a 450 mhz computer that is no small task, the encoding time is usually 3 hours or so, but, when i try to encode these 2 certain episodes the encoding time says it will take 10 hours not 3, the video is the same legnth as others i have done in the same program (TMPGEnc) & about the same file size prior to encoding & the projected file size is also the same as every other video i've encoded, but the estimated time says 4 hours first but then goes up steadily untill it says 10 hours, i have also tried to do this same video on a friends computer which is 2.5 ghz & even on his computer it says 4 hours when they usually only take 45 minutes or so, what could the problem be?
Are you using filters as filters can GREATLY increase encoding time???Originally Posted by AThemez
There's probably some bad frames in the video that cause the problem. I would suggest you to scan the video for bad frames using Virtualdub and that save a new copy of the avi. This should solve tha problem.estimated time says 4 hours first but then goes up steadily untill it says 10 hours, i have also tried to do this same video on a friends computer which is 2.5 ghz & even on his computer it says 4 hours when they usually only take 45 minutes or so
If there are any bad frames, use this guide to take them out:
https://www.videohelp.com/forum/userguides/142555.php
Hope That Helps!!!
:P
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 22:34 -
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 06:10 -
mpg to avi(xvid) problem
By okman in forum Video ConversionReplies: 4Last Post: 6th Jun 2009, 05:00 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 01:52
