I am creating a project in PAL and then recapping it to NTSC, however the audio is a 5.1 mix taken from the PAL version. Does anyone know if i can just use the same audio for both or will it be out of sync
thanks for any help,
am using scenarist 2.6
and Sonic SD-500 encoder
-Bish0p
Hi,
Technically you should be fine using the original audio, since there is no difference in audio streams for PAL/NTSC. The bitrates for PAL and NTSC are the same, it's just that PAL uses a higher resolution with a low fps than NTSC does.
hope this helps.
greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success !
Need to resample PAL audio to NTSC audio. Is it possible?
By mob in forum AudioReplies: 8Last Post: 28th Jul 2013, 23:51 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
pal audio convert in ntsc audio?
By ashe09 in forum AudioReplies: 4Last Post: 12th Oct 2011, 05:49 -
convert audio from PAL to NTSC
By Ankin in forum Newbie / General discussionsReplies: 18Last Post: 15th Aug 2009, 17:13 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
