Recently I have been trying to use 99min/850MB cd's instead of
80min/700MB ones so that I can have a higher bit-rate and not have
to go to 3 CD's for a movie. I use the same set-up that I use for
the smaller disks (which works fine for the small disks!).
Smartripper, then DVD2AVI, then TMPGEnc, then VCDeasy for the
chapters, and finally NERO to burn the image file. However, when I play it in my DVD-Player, it starts to loop towards the end of the disc, restarting in the same spot every five seconds even though there is about 5-10 minutes left.
Any ideas what could be causing the problem ? I have to enable
overburn in NERO because it refuses to acknowledge the larger disc.
Could that be the problem ? HELP !
Thanks,
Weasyl
