I've tried backing up Beauty and the Beast with both IC7 (doing the entire disc) and DVD2One and I keep getting the same problems. In fact with 1.11 of D2O it didn't even do the menu correctly. I've given up on an entire disc replica because of both the numerous problems, plus the size constraints (original is like 8GB using 1,000,000... bytes as a GIG) so...if anyone could please just tell me which titleset (using dvddecrypter) is the original movie so I can be on my way. (hopefully this works ...) i want just the original movie and NONE of the extras.
I just did that movie. All I did is the main movie with DVD2one. It is a complicated one cause it's interlaced, seamless branching and multiple pgc's
. I just ripped the main movie with DVD decrypter and used DVD2one to process it. Works like a champ. Any questions email me. If you want to have some Title's or a few extras, then refer to BARRYHL's guide in the guide section on this forum bud. Good luck.
TeF -
I did the entire movie by ripping the entire thing with smart ripper and then using ic7.0. Menus and everyhting work fine. I even used cheap media from supermedia store 39 cents each.
I backed up this movie and other Disney animation titles using this method that shadow runner suggested: https://www.videohelp.com/forum/viewtopic.php?p=386778&highlight=disney+animated+flicks#386778
You'll get the movie only, but it will fit on a single dvd without having to reencode.
prediction: "Bulldozer" will be a beast
By deadrats in forum ComputerReplies: 6Last Post: 3rd Oct 2011, 06:37 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50
