    Mar 2003
    Calgary, Canada
    I'm having some weird problems with DVD2ONE. Firstly my 'Enemy of the State' will not properly back up. I rip with DVD Decrypter as normal but when I go to use DVD2ONE it works at first then after about 30% way through it gives me the 'Completed-click okay button'. When I check my hard drive it makes the normal VIDEO_TS.IFO/BUP and VTS_01_0.IFO/BUP and only the first 2 VOB's (and only half done VTS_01_2.VOB). I have no idea, I even tried SmartRipper with the exact same results. And 2nd thing I've never seen before is backing up '6th Day', the Rip works great with DVD Decrypter but when comes time to use DVD2ONE to compress there's NO AUDIO only the video. I've tried re-installing DVD2ONE but does'nt seem to help. I've backed-up'd about 10 of my DVD's already using these programs with 100% success until these last 2 movies. I'm out of ideas, any help would be great.
  2. Problem "1" could be that the original has some bad code on the disc. I had a similar problem with another DVD movie so what I had to do was extract the VOB that was giving me a problem separately then put it back where it belonged in the final VIDEO_TS folder.
    The other issue I'm not sure about. Have you tried selecting other audio channels and see if they at least work? Perhaps try selecting all the audio channels.
    Mar 2003
    Calgary, Canada
    Yip, yer right Bob (reguarding no sound). Selecting all the audio channels did the trick (guess it really wanted the French AC3 6 channel...heh) I'll try your other suggestion see if that works...
