I've tried everything I know how to do (or read on this site). I'm trying to convert .avi files to the VCD format (.mpg). Here is what I have tried:
a) TMPGEnc - I get the following error: "file can not open or unsupported". This is the only error I get.
b) avi2vcd - I get the following error: "file contains compressed audio...which is unsupported".
c) Virtualdub gives a similar error code.
Can anyone help?
Shockme
it may have ac3 sound. try using gspot. it tells you what codecs the file uses.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Does the file actually play on your PC. Are all the codecs for your file installed?
The file does not play on my computer. I tried to find out which codec the file uses with gspot. However, the file doesn't work with gspot. In fact, it crashes the program. Other files work fine with gspot. However, the couple I have that do not work will crash. Any other suggestions?
Shockme -
To extract the audio to WAV from avi, use NanDub.
Use FourCC to make the file compatable (DivX)
If you still getting errors, check out my post "serious help..." - I might have a similar problem.Thx in Advance!!
Converting Avi to Mpg using ffmpeg
By sumit_pankaj in forum Video ConversionReplies: 5Last Post: 31st May 2020, 20:42 -
Aegisub wont play mpg, converting using divxland causes problems
By denadel in forum SubtitleReplies: 2Last Post: 2nd Oct 2011, 04:36 -
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 07:05 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 04:30
