  1. Hello,
    How can I make a DVD from 2 divx avi files.
    Here is more info on the files I want to convert/author to one NTSC DVDR:
    Two Divx .avi files (part 1 and 2) with AC3 sound
    Ripped from PAL DVD, so these .avi files are 25fps
    Widescreen 640x352
    Total time for two files is two hours
    I don't want menu's, just chapter every 10 mins
    How is it possible? How to avoid out-of-sync problems when it will convert 25fps to 29.97fps? Any comments would be appreciated.
    Thank you.
  2. Try reading the framerate conversion guides (under convert section to your left) Then when you have done this, try the authoring guides. Surprisingly these are listed under author.
