Deinterlacing isn't really the culprit. Even if we had completely progressive frames to start with, converting from 50 to 60 or vice-versa would introduce some type of artifact. I have some HDTV content (http://www.eecs.umich.edu/~balazer/hd_ads/ESPN_HD.ts.zip) that is 60 progressive fps (well OK, it's 59.94 progressive fpsConversion from PAL to NTSC is producing results that are not 100% satisfactory (the converted file does not have as high quality, especially on motion as the original), which is annoying. Yes, I blame deinterlacing for it...), and it would suffer from the same type of jutter if I converted it to 50 progressive fps.
The most common standards conversion devices use a technique known as "four-field" standards conversion and that doesn't use anything like deinterlacing. Some technical details are available at Snell & Wilcox's homepage (http://www.snellwilcox.com/) under the Reference section (see the Engineer's Guide to Standards Conversion). But the technique I created using a smart deinterlacer actually outputs video that looks a lot like the four-field technique, when you use ConvertFPS().I don't know if I'd go so far as to say "ever," but I think it'll definitely be a long time...and have read about the advanced motion estimation deinterlacing techniques used by pro's. This may not ever be available to us enthusiasts, if I understand Xesdeeni's response correctly.Well of course, but good luck finding a multi-standard TV in the US.I feel strongly that the best thing, if one is seriously interested in getting the best possible quality, is to get a multistandard TV and multistandard DVD-player, so no conversions are needed.I think I have enough interlaced PAL material (I don't have any film), but I don't have access to a PAL display system, so someone who can judge how well NTSC to PAL conversions are doing would be helpful.Xesdeeni, if you need interlaced PAL-material for testing purposes, I'd be glad to supply some.As I suspect you realize, there are basically two types of video content: that which originated on film, and that which originated on video.Also, if TMPGEnc cannot handle the audio part in television system conversions, how does your script manage to keep the audio in sync when going from PAL to NTSC?
Is this even a difficult task? Since the length of the converted video is the same as the original, what needs to be done to make the audio fit?
For content that originated on video, which is truly interlaced, the technique I created works best. And, since the resulting conversion is the same length as the original, no conversion of the audio is necessary.For content that originated on film, the same conversion can be used, but the quality will not be the best that could be accomplished, and it will not be quite as good as the interlaced-to-interlaced conversion. In this case, it is best to reduce the video back to progressive frames and change the speed. This is the type of conversion that TMGPEnc can do (that's how I do it on my Standards Conversion page: http://www.geocities.com/xesdeeni2001/StandardsConversion), but this is also where the audio needs to be adjusted.I have only used your script on interlaced 25 fps PAL video. No film conversions, the footage was shot on native video.
Lots of people use BeSweet to do the conversion, but on my Standards Conversion page, I actually just use AVISynth for simplicity. But of course both of these techniques change the pitch of the sound while changing its speed.
I've recently posted some messages about a utility (http://www.geocities.com/xesdeeni2001/WSOLA.zip) I snagged to do the conversion of the audio without changing the pitch. The creator claims that it produces no artifacts (http://aulos.calarts.edu/pipermail/music-dsp/2002-May/015962.html), but I still haven't gotten any feedback on it.
Xesdeeni
Results 31 to 33 of 33
I am thankful for your script and have been meaning to tell you so for a while, but this is the first appropriate occasion.
If I can help you in your development of conversions, it'd be my pleasure. -
Have you checked out the Sony models?I am willing to be your test pilot. I can also send you some PAL film material (Mpeg-2). Either as an SVCD or Mpeg-2 (720 x 576, hopefully DVD-authoring ready). I am waiting for a DVD writer to arrive, so I can only send material on CD-R as of now.
Xesdeeni
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
