ive tried encoding a couple avi to mpeg with tmpgnce. but it seems like no matter what bitrate i set tmpgnce at it always gives me a very large mpeg file when its done encoding. always over a gig. ive even set the bit rate to encode as low as 300 MB but i still get a file over a gig when its done. can sombody help me please.
300MB might be your problem.
are you using 2.59?His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
well i tried to set the bitrate at 300 MB just as a test, but it still came out over a gig, usually i was trying to encode so the file would be 800 MB, but it never works.
you set the bitrate at 300MB a second?
are you using version 2.59? that one has a bug that makes the file larger than it should be.
Japanese VRO Disk problems
By HDBoxing in forum Software PlayingReplies: 15Last Post: 19th Dec 2010, 23:13 -
Changing AC-3 Bitrate (Problems with AC3gain)
By dabas in forum AudioReplies: 3Last Post: 30th Jan 2010, 15:55 -
Possible hard disk and computer problems..
By SE14man in forum ComputerReplies: 5Last Post: 18th Oct 2008, 19:10 -
Problems with Dual Layer disk burning.
By qaa in forum Newbie / General discussionsReplies: 19Last Post: 21st Apr 2008, 02:47 -
Vista and intel AHCI disk controller problems.
By ofbarea in forum ComputerReplies: 8Last Post: 20th Nov 2007, 21:36
