why is it when i dvd2vcd it takes so long to convert a divx file (which is using tmpge ) as appossed to using just tmpge? the problem im also having is audio sync problems when i just use tmpge
DVD2SVCD is a front end program that runs several other programs for you. The seperate audio encoding, video encoding, and muxing could be why it's takes longer to run than running TMPGenc alone. For DivX files I would just use TMPGenc alone. As the name implies DVD2SVCD is really to make live easier for newbies that want to back up DVDs.
The audio sync could be caused by several things. More than likely the bbMPEG muxing script as 'an error' of some kind.
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 22:55 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 07:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 10:13 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51
