Ok so here's the deal I've been trying to convert this movie I downloaded to mpeg2, after some problem getting it into tmpg I suceeded, however after it was encoded only the video file worked and the sperate wav file did not, I've tried abunch of formats for the audio but I get no sound, should I use some other program to encode the audio?
"So let me get this straight, you pull it out and I suck?....is there any money in it for me"
What kind of audio is it??
Use gSpot to check the avi"I´m not popular enough to be different" -
Gspot says it's mp3....
"So let me get this straight, you pull it out and I suck?....is there any money in it for me" -
How did you extract the audio??
Also are you making svcd or dvd? SVCD requires 44.1khz and DVD requires 48khz"I´m not popular enough to be different" -
Well I used vdub to extract the audio just recently and that worked but when I burned it to a dvd I get audio for abit then after awhile both the audio and the video freeze...everything works fine when I watch the files on the computer though
questions about audio normalizing and audio encoding
By codemaster in forum DVD RippingReplies: 2Last Post: 25th Sep 2011, 21:22 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
best audio encoding?
By Remyisme in forum Newbie / General discussionsReplies: 4Last Post: 20th Oct 2008, 04:44 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 19:53
