I have this player, the daewoo 5000n which will play anything. However, I noticed that movies tended to play darker with more red in some areas. Not very bad.....but then again, who wants to adjust the TV to be brighter.
I then purchased a Koss portable 2161 with same svideo outputs.....BOOMMMMM.....this thing is a lot brighter.
I assume all DVD players are not created equal. Anyone have this problem with DVD players that play too dark?
Any DVD players you would not buy because they play too dark.
thanks
never seen one play to dark how are you hooking it to the tv?
I have 2 daewoo's a DVD-5700 and a DV6T811N both play everything I've made without any problems. Also just recently purchased a Toshiba with the same results as the Daewoo. -
Its not dark dark.....but the koss appears to have better contrast. Maybe its just that the koss is brighter rather than the daewoo being darker.
Anyway, the advantage of the Koss is that it handles 23.976 3:2 pulldown better than the daewoo because I get less fast motion on some scenes.
daewoo is good......but I think there better dvd...
hookup same on both units.....
Darker label with Lightscribe
By omega_weapon in forum MediaReplies: 9Last Post: 26th Apr 2011, 18:53 -
DVD recorder Daewoo DL-3100
By Leonora in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Apr 2009, 06:35 -
Travelling darker columns on VHS
By Cole in forum RestorationReplies: 2Last Post: 15th Mar 2009, 14:09 -
DVD Daewoo DS-K960U
By TonitoDJ in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th Oct 2008, 09:08 -
WinDVD8 unlike 4 gives darker picture
By DBenz in forum Software PlayingReplies: 0Last Post: 18th Jan 2008, 17:31
