i have pinnacle instant copy v7 and i have found 2 flaws. maybe there not flaws....maybe there my mistakes during the encoding process. but here is the first one. when i slide the bar all the way to 4.31GB .....and after about 2hrs of encoding i get the finished product in pdi(or something like that) format. the finished image is only 3.91GB. i dont know how this happens cause all of the finished encoded images are 3.91GB and not the full 4.31GB that i chose when i slide the bar to that amount of space. and that kinda bothered me but i burned the image anyway using the same program. once that was done i put in my dvd drive and it said disc error after the warning message. and if i press play again it goes straight to the movie. if i hit menu it goes to the menu but when i press on a special feature..it gives me a disc error message. has anyone had or have this problem. if there's a way to fix it .....let me know![]()
Results 1 to 9 of 9
I don't use Instant Copy much because it's so slow but I always just leave the slider on "Auto" and the file size is always 4.36GB. Lately I have been using DVD95 Copy which is much faster http://www.dvd95copy.com/purchase.htm
i have seen the same problem...mostly it turns out smaller than what i specified but once it was actually larger, infact larger than 4.7...
wierd -
i read somewhere in the forums that pinnacle has an option in the software that makes the ok button enabled even if the size goes over the 4.31GB limit. i wonder where it is...could u guys or someone out there enlighten me on this matter.
If you manually oversize the dvdr (4.6 Gb works for me) press the F5 key, this re-enables the start button.
Movie only DVD9 to DVDR guide.
http://www.angelfire.com/droid/dvdr/guide.htm -
thanx dilligaf.....i will definitely use this as my movies are only 3.91GB. and i could really use the extra 300MB
I just backed up a DVD using the "oversize" method on IC7 and it created a 4.2 gig folder.
I set the size to 4.67 on IC.Use what works for you... -
thanx for posting ur results here as i now have an estimate as to how much i should move the slider bar.
Software Instant replay systems
By CaptainIcebergg in forum Video Streaming DownloadingReplies: 0Last Post: 29th Dec 2011, 18:50 -
After a certain software (may not even exist but thought id ask!)
By SE14man in forum ComputerReplies: 16Last Post: 18th Oct 2011, 19:36 -
Mirror copy of Pinnacle DVD
By Straightlegger in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 12:40 -
As good as Pinnacle
By Vaseman in forum EditingReplies: 20Last Post: 8th Sep 2009, 11:10 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 18:29
