Tmpgenc wont accept my .d2v file from a recent dvd rip. It says it is a unsupported file type? I looked through this forum and saw somebody had same problem. He found the answer but didn't post it. Please could somebody give me the idiots guide to where I'm going wrong.
Thanks.![]()
Results 1 to 9 of 9
I found this post on a search hope this helps
cdcox
Originally Posted by vukodlak75 -
hi!
in order to have tmpgenc open the .d2v file, you have to have dvd2avi registered where it is and where the dvd2avi.vfp file is.
just put dvd2avi.exe and dvd2avi.vfp in one directory of your choice.
start dvd2avi.exe once and make sure the "register to VFAPI" is checked in the menu (i think it's in the "about" menu).
then you can open the .d2v file in tmpgenc.
and don't mess with different versions of dvd2avi.
v1.77 won't read v1.76 files and vice versa.
if you have both versions of dvd2avi, the one last started will be the one tmpgenc will use.
that's all.
quite simple for my taste.
of cource if you use more than one computer, you have to have dvd2avi on both computers, and you have to at least start it once on both computers, so it can register is's VFAPI plugin.
if you prefer, you can of course copy the dvd2avi.vfp to tmpgenc's folder ... i prefer to keed dvd2avi registered correctly, but it should work both ways.
bye,
--hustbaer -
LOL! that animation of the smily face is hilarious!
did you make that? i noticed its not in the emoticons selection menu.
very sweet
Syndrome -
When posting beneath the emoticons there is text that says 'View more emoticons'. There you'll find loads more.
Idiot's Guide to Encoding
By sharpfocus in forum Newbie / General discussionsReplies: 4Last Post: 11th Sep 2011, 20:59 -
An idiot and a video_ts folder...
By CitizenErased in forum Newbie / General discussionsReplies: 11Last Post: 24th Jan 2011, 17:00 -
Idiot proof way... Blu Ray to WTV
By Chakotay2 in forum Video ConversionReplies: 1Last Post: 27th Sep 2010, 07:17 -
Mozilla is becoming *VERY* idiot-friendly :-(
By Midzuki in forum Off topicReplies: 10Last Post: 25th May 2008, 17:12 -
Nero help for newbie IDIOT
By bbassboat in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2008, 18:32
yes indeed
