I'm converting a DivX 5.01 movie, 640x272, 23.976 fps to VCD for playback on a NTSC TV. My TMPGEnc settings are size: 352x240, 23.976 fps, and Aspect ratio of 4:3 525 line (NTSC). The final result is stretched from top to bottom; people look elongated, in other words. How do I convert a source file of this type so that it fits in a standard TV screen but retains its natural proportions? Thanks!
Click on settings, then the advance tab. Set the source to 1:1 VGA, keep the output as 4:3 TV, then set video arrage method to 'full screen keep aspect ratio.'
TMPGenc should then center the video and add black bars at the top/bottom as necessary. -
No problem, you might want to read up of Display Aspec Ratios (DAR) and how anamorphic DVDs work (here or at doom9.org under the basics).
Summary: There are three DARs that you're likely to care about.
1:1 for PC video
4:3 for standard TV
16:9 for widescreen TVs & film
However, under the general term 16:9 you have
1.77:1 widescreen and HDTV
1.85:1 academy flat
2.35:1 anamorphic widescreen
Aspect Ratio
By mistycat in forum Video ConversionReplies: 8Last Post: 8th Nov 2007, 02:43 -
Aspect ratio??
By frednufc in forum Video ConversionReplies: 1Last Post: 14th Oct 2007, 15:11 -
what is aspect ratio?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 3Last Post: 29th Sep 2007, 22:29 -
Aspect ratio
By Digiface in forum Software PlayingReplies: 2Last Post: 24th Aug 2007, 12:35 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 13:27
