i dont know if anyone else has backed this movie up, but ive run into a little snag. the dvd has 2 vobs sets, one for full screen and one for widescreen. i just dumped the fullscreen and a few trailers and the movie fit fine without any re-encoding/transcoding blah blah that i would normally do with instantcopy. so anyway, the movie and menu fit fine on the dvd, burned fine, and plays fine in my mintek 1600 EXCEPT that when i tell it to play the screen where i would choose between full and widescreen flashes up for a second, not letting me choose one, then i get a strange cartoon smiley face that flashes red when i press the play button. i assume this is some kind of copy protection, but i have never run into it before. what i dont know is if its from the dvd or my player, becuase it seemt to work fine on my dvd-rom drive. unfortuanatly i have but one dvd player that will play backups. i would like make a copy that works, so i was wondering if anyone else had run into such a problem before. thanks in advance for any help you may offer. if you have any questions or need me to clarify, feel free to speak. thanks again.
ocramolop
I think it is from your player. I have backed up the same movie (widescreen) and have had no problems. I used Instant Copy for the encoding proccess.
Regards
SteveWe all gotta start somewhere!!!!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Easy way to default existing subtitle to "on" when backing up?
By Spoffo in forum SubtitleReplies: 1Last Post: 30th Jan 2011, 22:50 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 22:28 -
Problem "backing up" Confessions of a Shopaholic
By jamesprime4328 in forum DVD RippingReplies: 4Last Post: 3rd Sep 2009, 15:15
