I downloaded a movie that says it's a .Divx.AVI file. The file refuses to play. I have installed the latest Divx Codec and Nimo Codec Pack. In windows media player when I try to open the file, I get a message "Cannot playback file format not supported". When I check the properties of the file it says that the file is invalid or corrupted. When I try to play the file on Divx player 2.0, it says: "will not open, check if it is a valid AVI file". I did not know if the file was broken so I tried Divx Fix and it said the file was not an AVI. I tried G spot to find out what type of file it was and it said that the file was not a valid AVI file. Can anybody shed any light on this problem? Is this file junk???
Thanks,
TC![]()
The movie most likely is an ASF file. You should never download fakes.Originally Posted by fulci
Use Avipreview to check out the file during the D/L, it's in the Tools section.
"Art is making something out of nothing and selling it." - Frank Zappa -
ASF:Originally Posted by fulci
Advanced Streaming Format (ASF): This file format stores audio and video information, and it is specially designed to run on networks like the Internet. This file format is a highly flexible and compressed format that contains streaming audio, video, slide shows, and synchronized events. When you use .asf files, content is delivered to you as a continuous flow of data. You no longer have to wait for your audio and video files to fully download before you start to view them. When an Audio Video Interleave (.avi) file is compressed and converted to an .asf file, the file begins playing after only a few seconds. The file can be unlimited in length and can run over Internet bandwidths.
Hope That Helps!!!
:P
virtuldub can not open avi file?
By wuqingshi in forum EditingReplies: 6Last Post: 1st Sep 2011, 20:40 -
valid ts file
By qman7112 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2011, 15:35 -
RMVB to DIVX (Cannot open file)
By leogeo in forum Video ConversionReplies: 5Last Post: 24th Nov 2008, 21:14 -
cannot open avi file
By ione in forum Capturing and VCRReplies: 8Last Post: 14th Sep 2008, 21:02 -
Not a valid avi file and Unable to insert......
By tommyboy9495 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2007, 22:11
