I have the following problem with the subtitles. I have an *.srt witch i converted with subrip to an *.son file but in dvdmaestro it says that its an bad file so what can be the problem i am using the doom9 guide and there is not much to find out what the prob can be.
Did subrip also generate all of the need BMP for/of each subtitle? I would give MaestroSBT a try (you can d/load it from doom9.org). This will generate the son file AND all of the needed BMP files.
How to write randomizer script in DVDMaestro
By GomezOptions in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2011, 01:15 -
DVDMAESTRO sx32w2.dll
By twinegar in forum Authoring (DVD)Replies: 1Last Post: 16th Mar 2010, 13:04 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Wrong frame rate (30 fps) for DvdMaestro. Any solutions?
By conax in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2009, 18:36 -
How to add multiple audio tracks in DVDMaestro?
By rbatty11 in forum Authoring (DVD)Replies: 0Last Post: 5th Sep 2007, 08:48
