I have a 900mhz duron and a tv wonder ve. I want to capture some shows and convert them to either standard vcd's or cvd's. Does it give better quality if you capture at a higher resolution and then encode at a lower resolution then you captured at, or does it not make a difference, for example capture at 480x480 and encode at 352x480 as opposed to capturing and encoding at 352x480.
It's best to capture at a "multiple" of what resolution you want to encode to. Thus if you want to encode to CVD resolution 352 x 480(NTSC) then capture at either 704 x 480, or 352 x 480 resolution. I have noticed "some" improvement (under certain circumstances) capturing at 704 x 480 and then during the encode resizing to 352 x 480. With your limited hardware, I suspect you will be dropping frames, or fill up your hard drive capturing at 704 x 480 resolution. I have a "powerfull" system, since most of the time I get good to excellant results capturing at 352 x 480 resolution, I do use 352 x 480 as my default capture resolution even when I intend on making VCDs.
what resolution will a DVD recorder set-top capture.
By xbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 11th Jan 2012, 16:40 -
Set to Capture @ 720p on Hauppauge HD-PVR?
By yic17 in forum Capturing and VCRReplies: 4Last Post: 16th Jul 2011, 20:48 -
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
Set up security camera with a usb capture device -- help please
By brenda035 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jun 2010, 10:01 -
What level should I set the audio to when capturing analog in VirtualDub
By drinklime in forum AudioReplies: 3Last Post: 20th Jan 2008, 09:45
