I know when a product is initially released, there are usually some bugs in the first batch of players made. The most recent models usually have these bug problems solved. The DMR-E30 that I just bought was manufactured in JUNE 2002. The previous one I had was in the FALL of 2002. I haven't had any problems in the 4 discs that I have burned and finalized so far (all Verbatims, of course). After having 2 DMR-E30s, I didn't even know that the fan was even used on these units b/c you can't even hear it. The only way you know it's on is when you place your hand behind it (you can feel the hot air being pulled out) or you aim a flash light at it in order to see the fan spinning.
I just got my DMR-E30 and it was manufacturered October 2002.
I have had it turn itself off when recording to one DVD-R Disc I got at WalMart - but the mulk Accu discs I got (79 cents shipped) are working fine.
Sony/Panasonic m2ts file date correction
By renzo2000 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Aug 2010, 16:07 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 20:57 -
panasonic dmr E30 compatibility
By jimakros in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Dec 2008, 12:19 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45 -
Panasonic SDR-H18 Date/Time Stamp!
By carbfrze in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 29th Jul 2008, 09:16
