Hi,
Converted a Divx NTSC to VCD and it played on my DVD player. Then as my player doesn't play SVCD tried converting to SVCD using the VCD header trick and it too played.
So both work but the colour is not correct and the there are very thin black lines across the screen.
As I live in New Zealand I tried converting to PAL which is the standard here.
VCD went well .Colour was correct and no black lines.
SVCD with the header trick has not gone well. Playback but is jerky. Audio and video are in sync. Colour correct and no black lines either.
I really want to use SVCD as the picture quality is so much better.
1. Used TMPGenc to do the converting.
Could the problem be when changing the frame size from the source of 480X320 to 480X576?
Results 1 to 1 of 1
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 05:02 -
151MB mp4 file - with header problem?
By supermaster in forum RestorationReplies: 7Last Post: 6th Jan 2012, 09:52 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 12:23 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21
