Hey Guys,
Finally got some Ritek's so now I am gonna begin copying all my Princo's to them, etc.
I had a quick question, is it possible to add a zip file of say all your cover jpg's and maybe text documents of movie info into the DVD's file structure ?
I'm burning the files / folders out in Prassi, so I'd add them following authoring/rendering of the TS dir's...
I have tried it in the root, that did not work at all. I was wondering, can you drop it in the AUDIO_TS folder since it's empty ? Can you add a folder in either of the TS directories that will not interfere ?
It'd be nice to add all the extras in for others if you copy the disc, then they can make labels, etc easily without having to re-hunt for the info, or in my case, due to Princo's issues, I wouldn't have to redo all teh labels...
Thanks Guys, for any and all helpHope all's well with everyone
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Spidey,
I wouldn't put your file in the root or even the TS directories. Just simply create another directory and pull all your guff in there. it'll be just fine.
What I usually do is create a file and stuff my original DivX films so in the event of a coasted DVD I can still play the film on a PC.
Keep thwipping Spidey -
Hi Ironballs,
Thank you very much for the info
So I can simply create another folder in the root of the disc ? I had done it before, but simply added a zip file in the root. It did not like this at all
Anyhow, so a discs root would look like
:\AUDIO_TS\
:\VIDEO_TS\
:\JPG\ or \INFO\ or \SOURCE\
Something like that ? Should it be in CAPS ? I am only interested in getting into it on the pc's, so it's really just a storage type area.
Thanks again for all your help Bro !!!!!!~~~Spidey~~~
Spidey, your structure should be fine. I'm ceratin that compliant DVD should have the AUDIO_TS and VIDEO_TS files in caps so I always use caps for other direcrories, hell how much effort is there in hitting the caps key!!!
BTW some sofware won't create the AUDIO_TS directory, even though there is nothing stored there, always create it for maximum compatability.
Cheers Bud -
Ironballs,
Thank you again very much. I wasn't sure if the INFO dir being placed in the root, since alphabetically it falls in between the a/v ts dir's would cause an issue.
All sounds great and I'll give it a whirl right now. I am using Prassi Primo DVD to burmn, so adding the dir's is no problem at all.
Thanks again very much Bud !!!!!
~~~Spidey~~~
not move the file tmp dir to upload folder
By velayudham in forum ffmpegX general discussionReplies: 2Last Post: 19th Jan 2012, 18:32 -
Can you rip a dvd without the menu requirement...plz read for nfo.
By darkcyber in forum DVD RippingReplies: 5Last Post: 11th Jul 2011, 23:45 -
Adding Bmp/Jpg to Flav
By Soixante in forum EditingReplies: 0Last Post: 11th Jan 2010, 15:54 -
JPG to AVI Back to JPG is it possible?
By concisa in forum Video ConversionReplies: 3Last Post: 11th Apr 2009, 10:06 -
Can't unzip ffmpegXbinaries20060307.zip
By cerebusthe2nd in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2007, 09:39
