After I have encoded a Quicktime file into VCD format the program does not respond and I have to end the program and start over again. The conversion is completed but I have to restart TMPGEnc after each file. Any suggestions?
Don
It's not the 99% error(at least I don't think it is), it actually says 100% completed and does make a finished MPEG1, but the program freezes after that.
Don -
Why dont you first try converting the .mov to .avi with RAD VIDEO TOOLS?
Then try to make the mpeg.
http://www.radgametools.com/bnkdown.htm -
I actually originally did make the MOVs into AVIs with Movieshaker and then used DVGate to encode the MPEG1 and MPEG2 files, but the DVGate encoding gave feedback at the end of the file and I didn't realize this until I encoded 200+ files this way so I would like to use TMPGEnc to cut out the lengthy process of encoding an AVI. Good idea, although I'd rather just fix this slight set back of the current program (TMPGEnc)
Don -
Then its the 99.999% error
Have you tried loading the AVI into Vdub and chop a little off the end using "keyframes" I'm thinking that the audio and video are different lengths. The 99% error locks up TMPGEnc on movies like that, maybe your 100% is displayed a second before it actually finishes. -
I tried to convert mov to avi with TMPGenc, but it gives sound but no video.
ANY HELP!?!??! -
Use MOV2AVI.EXE, then use the *.avi file as video input in the TMPGEncoder and the *.mov file as audio input. This works without failure for me.
Quicktime conversion corruption
By teadle777 in forum Newbie / General discussionsReplies: 4Last Post: 17th Mar 2009, 20:54 -
problem with conversion from quicktime to h.264.
By savvyguy in forum Video ConversionReplies: 23Last Post: 19th Jan 2009, 21:49 -
Quicktime DV conversion
By suchuwato in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Jan 2008, 20:22 -
Uncompressed quicktime to flv conversion
By Ian J Richards in forum ffmpegX general discussionReplies: 6Last Post: 6th Nov 2007, 02:21 -
quicktime (.mov) conversion
By superstarx85 in forum Video ConversionReplies: 0Last Post: 11th May 2007, 05:10
