  1. Hi
    I am fairly new to this and was wondering if there is a way to put more than one movie on a dvdr. I have two movies with the ifos and vobs reduced to 2gb each and was wondering if there is software i can use to burn the movies so i can play them on a stand alone dvd player.
  2. You could make them into MPEG2 files using TMPGE and then burn them with anything like ULead moviefactory and make a menu for them to select which movie you want to play.
    Jul 2001
    e-z,
    See the post I just made here:
    https://www.videohelp.com/forum/viewtopic.php?t=149963
    You will need to convert the VOB first, but I think MovieFactory2 may be able to grap those as input as well. Hope its helpful...
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
