can any 1 help i am trying to back up 2 dvds on one disc i can manage 2 resize ok using dvd2 one both vts folders only total to 4.3 gig which is ok its just joining them to burn how
You won't be able to as as DVDR disc will only hold one of the files. To reduce them down to fit on only one DVDR will mean another run through DVD2One and set the max file size at 2.18 Gigs.
