i use virtualdub 1.5.1,when i want to do the sound i get this error ,first i open file ,full compression mode and then save wav and then i get this error ,no audio decompressor could be find to decompress the source audio format,anybody knows ,thx
ac3?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
do you have all the codecs installed? I had the same prblem till I installed all the of the divx bundles and codecs.
Modartist
Some are born to rule the world. to live their fantasies.
While most of us just dream,
of what we would like to be. -
Gspot will tell you if you need a codec. That and the AC3 codec are in the Tools section.
Here's a guide for converting AC3 sound: https://www.videohelp.com/forum/viewtopic.php?t=91588
Or you can use Goldwave by loading your Avi in, then select save.
8)"Art is making something out of nothing and selling it." - Frank Zappa
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 20:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 08:45
