I use tmpg12 to convert .avi to .mpg, and they always show up as standard compliant before i burn it with nero 5.5. The audio is in sync when i watch it on the computer, but when i watch it on my apex 500w the video sometimes speeds up, and then slows down and the audio eventually catches back up with it, but i want to know what i can do to fix this problem
It's odd that it would play fine on your PC but have sync problems on the DVD player. What format was your source in? Is it possible it wasn't 30fps?
well, i tried burning it at 30fps, but still had the same problem, so i tried 29.97fps. Is there anything i can do to fix it?
this happened to me all the time. the first half of the movie plays fine on my pc, but the second half plays horrible on my standalone. I swithced over to svcd and it fixed the problem.
i had this problem when i encoded to vcd. instead of encoding to vcd, encode to svcd. the result is better and the audio not matching with video is not a problem anymore.
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 15:23 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 07:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 06:23 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
