I've been making regular vcds with chapters using VCDEasy but now I'm making XVCDs with higher bitrates and can't create chapters anymore. When I run the mpeg through VCDEasy, it tells me it only has one entry point and won't allow me to create the ususal chapters at 5 minute intervals that I was using before. Anyone know why or how this is happening? Thanks
Yes you can.
You haven't set the right settings when encoding your XVCD MPEG clip.
If you use TMPGEnc, make sure that you set the MPEG Sequence Header interval to "1 GOP".
A possible fix for your existing MPEG files: https://www.videohelp.com/forum/viewtopic.php?t=126292&highlight=
Regards.Michael Tam
w: Morsels of Evidence
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:16 -
What is the best way to cut up an Xvid file or add chapters to it?
By Chrushev in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2010, 05:14 -
It is possible to add chapters in divx dvd ? subtitles ?
By carl25 in forum Authoring (DVD)Replies: 7Last Post: 2nd Jul 2009, 23:06 -
Need to add chapters to a 3GP file
By fredsp in forum Video ConversionReplies: 4Last Post: 22nd May 2008, 03:22
