Here's the situation - I used to be getting ghost images and some other interference using the coaxial connection on my PCTV Pro card, so I switched to the composite input and it works beautifully now. For the audio, I run the l/r out of the VCR to go to the line in of my soundcard. Before when I was using the coax, there was a audio out on the PCTV card that went to the line in on the soundcard, and when I did a capture the audio was always in the correct format (48000). Now that I've split it up, the audio is always captured at 44100 since it's not going through the capture card first. Is there any settings in Windows 2000 to change this? I'm using a Turtle Beach Santa Cruz card if that helps. It's not THAT big of a deal, it just now has to render all my files in DVD Movie Factory 2 when before it never did - adding about 3 hours to any project.
Hope I expalined everything ok.
