    Dec 2002
    Scotland
    I am getting a really strange problem when using Ulead DVD MovieFactory 2, the text colour on all my menu pages apart from the first are black on the final output even when I select white. It even shows the text colour on the preview as white before I output it.
    Anyone have any ideas?
    Best Regards.
    Barry
    God's in his heaven... All's right with the world!
    Robert Browning (1812 - 1889)
  2. Here's the solution that someone else posted before and it worked for me. It's a little tedious, bit it works:
    Let's say you have a 3 menu pages, and all have white text. The first one shows up ok and the last two don't. What you have to do is go to the LAST menu page and change the color to something other than white, then do it for the SECOND menu also. After that, go back to the LAST menu and change it back to white and then do it for the SECOND menu also. Your ourput should now have white text for all menus. For some reason, MF2 changes every menu after the first one to black text.
    Hope I explained it ok.
    Dec 2002
    Scotland
    Thanks you explained it well, I will try it tommorow.
    Best Regards.
    Barry
