Hi all. I am currently using the S-Video IN on my Xtera Geforce 4 Ti4600 128mb video card to capture video. Using Virtual Dub and Huffy codec. I use it to capture for burning DVD's.
Back in the days of my older system, I had an ATI TV Wonder with S-Video in to capture for VCD's, and I also used Virtual Dub.
When the video is captured as an avi, I notice NO difference in the video quality between the cards.
So my question is this...does the video card/capture card you use to capture video REALLY make a difference?
It depends on what you're using. Some cards can't even capture above 320x240 so obviously they'd be substandard. Professional level cards may be better than the consumer types, but I don't think there is a large difference between the ATI and NVidia right now (and they're pretty good).
When I replaced my AIW 128 with Gainwards GF4 I noticed a slight difference, including a small mask on the left 4 columns of pixels (odd...). The differenced weren't really enough to worry about.
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48 -
Video capture card help! How do you capture from video card (desktop)?
By AtiMike in forum Newbie / General discussionsReplies: 3Last Post: 24th Jun 2008, 16:50 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
