seemingly out of nowhere, some of my .mpg movies, during playback, have a strange image that bounces randomly around the screen. i took a screenshot of what it looks like here...
i tried playing the movies with 4 different players, all the same thing. it happens with some .mpg's but not all (maybe the mpeg2's do it and not the mpeg1's?) if anybody has seen this or know what the heck is going on please let me know! thanks!
Yeah, I've seen this before. What's happening is that you are using the Elecard MPEG2 decoder.
For some unknown (to me) reason, after a little while the new version of the Elecard Decoder (version 2) starts going nuts and spraying the Elecard symbol all over the movie it is decoding.
I don't know if this is beacuse they want you to pay or what, but if it is because of this their documentation doesn't mention it or does a piss-poor job of it because I didn't find an explanation anywhere on there site.
I would suggest uninstalling the Elecard codec (should be accessible through the Windows add/remove programs Wizard) and using a different MPEG2 decoder. I suggest the Fraunhofer codec available here:
http://www.doom9.org/Soft21/Filters/freedvd.zip
It's free and works fairly well
Hope this helps,
Prospero -
well the elecard software is now shareware and after 20 days you get the bouncing box. i have tried to locate other codecs to use on this pc at work without having to install a software dvd player. i did just try that link above..but i get errors of file not found when i run the bat file. any other suggestions?
Is playback of mpeg-ps streams possible on a pc?
By craig198 in forum AudioReplies: 2Last Post: 26th Apr 2011, 12:12 -
Choppy playback after converting an MPEG...
By takearushfan in forum Video ConversionReplies: 23Last Post: 7th Oct 2010, 13:32 -
VirtualDub doesn't playback .VOB or .MPEG right.
By Eneko in forum Video ConversionReplies: 7Last Post: 1st Mar 2009, 16:36 -
Will the QT MPEG-2 Playback addon help my no MPEG audio on vegas problem?
By Nuke Shower in forum Video ConversionReplies: 5Last Post: 9th Apr 2008, 17:01 -
MPEG video stops half way through playback
By lpmitch in forum Software PlayingReplies: 4Last Post: 4th Apr 2008, 23:15
