  1. I have an internetal SONY DRU500 DVD re-writer, and a Yamaha cd-writer. When using NERO I can see and write to both drives. MY COMPUTER can also see both drives and I can read from them no problem.
    Problem is DVD Movie Maker or RecordNow can NOT see the drives at all. Ive tried rescanning the buses but no look. Ive tried unistalling NERO but still no look.
    Ive updated my ASPI (correct?) and still no look. Any ideas?
    Im sure that it DVD Movie Maker did once detect my drive, so obviusly something has been installed that DVD MM & RecordNow dont like??
    Help please, otherwise im thinking of formatting my drive and starting again!
    thanks
    Dec 2002
    Belgium
    Do you have the latest version of RecordNow? You need a version that supports your writer.
    MrSnake
    Sony DRU-500A v1.0d
    Toshiba SD-M1302 v1006
    Philips DVDR885P v1.7/8
  3. i think I have version 4.0 I'll check. I take it their website says which version is for which drive??
    Thing is though DVD Factory/MovieMaker wont pick the drive up either! Yet it did last month when I last used it. Thats why im wondering if I've over written something?
    May 2002
    Austin, TX
    Also if you O/S is XP, I've seen problems with XP's internal burning capabilities that can do that.
    Are you using XP?
    "Signature"......
    I use a Dazzle capturing system that Only lets me capture into Mpeg. So that is all I work with. I never do any DV/AVI video.....
  5. im using Windows 2000. Ive since read that only version 4.5 & higher recognise the SONY drive...
    But that doesnt explain why DVD Moviemaker could see my drive last month, but when ive gone to use it now it cant see it..
    the mystery continues!
  6. i'm having the same problem. i run on windows 2000 advanced server and i have a memorex dvd/rw drive. i use ulead movie factory 2 and untill today, it recognised my drive and has burned dvds with no problem. nero still recognises the drive and so does my device manager, but mf2 wont see it all of a sudden. i dont get it. someone help please.
  7. ok, i've solved my problem. i uninstalled movie factory and then reinstalled it and it recognised the drive again. see if this works for you.good luck.
