I captured a TV-Movie and the result is a interlaced .mov.
Now, when I preview the .mov on my tv using quicktime, .... shure no problems cause the target is TV.
But ...., do I have to interlace the movie when encoding to m2v??? I mean, I will play back the movie also on TV using a DVD Player. Is it necessary to deinterlace the .mov????
Thanks!
Hi!
I think that you should not deinterlace, if your target is TV.
But you have to tell the mpeg2encoder do make a interlaced m2v, otherwise the picture quality will be bad!
Command line option for mpeg2enc: -I 1
Ciao, ALeX.
Question about interlacing
By ayim in forum Newbie / General discussionsReplies: 10Last Post: 7th Nov 2009, 13:19 -
interlacing question
By rakan in forum Newbie / General discussionsReplies: 9Last Post: 29th Oct 2009, 07:51 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 19:50 -
Interlacing
By koberulz in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 12:32 -
HD and interlacing hell
By jchansen in forum MacReplies: 2Last Post: 4th Sep 2007, 10:14
