I've captured a video tape that a friend had that he wants in DVD format. (source VHS tape, output to AVI Type-2) Problem is that there are some areas due to lighting that are VERY either a) washed out or b) high contract into red shift.
Any recommendations on getting this to MPEG-2 format without to much quality loss for DVD authoring would be appreciated.
I have been editing -> exporting to AVI and then using the highest quality TMPGEnc settings possible to still fit on a single DVD based on the info here : http://dvd-hq.info/Compression.html
This has worked fo animation and other captures from VHS, just concerned about spots that are going to be to bright or red
Any suggestions would be useful!
-trilli
Well I've taken the plunge and started using avisynth to frameserver to TMPGenc. I've run about three different encodes so far and none of them satisfy me all the way through the movie. One's to high of contrast, the other I get ghosting, and yet another leaves behind to many artifacts. Since I'm pretty much the newbie to avisynth ( 2.08 ) can someone offer any suggestions on some avs scripts that work well for decent quality VHS capture -> DVD without leaving to many artifacts, color shifts, or other anomolies behind?
-trill
Video Capture PCI / USB recommendation?
By harky in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 20:04 -
Need a recommendation on a new capture card/device
By MJDore in forum Capturing and VCRReplies: 1Last Post: 14th Oct 2011, 16:56 -
need capture card recommendation
By mysts in forum Capturing and VCRReplies: 3Last Post: 30th May 2010, 20:52 -
Need Capture Device recommendation advice!
By unclekracker in forum Capturing and VCRReplies: 4Last Post: 2nd Apr 2008, 12:54 -
laptp capture card recommendation
By theduffer in forum Capturing and VCRReplies: 0Last Post: 2nd Mar 2008, 10:26
