I have a 3 hour movie and have used TMPGEnc to get it down to 3.9GB so it will fit on a DVD. My DVD 4.0 won't burn it - says it is too large for media. Will Nero burn it for set-top use? Looks like Nero requires VIDEO_TS folder. What app will make this folder from the TMPGEnc MPEG2 file?
Jay
If you are planning on burning without any menus, ifoedit will do an excellent job of authoring out to a VIDEO_TS directory. If you are lucky enough to find a copy, SpruceUp! will do the same as well as DVDMaestro.
Here is a link to the guide in the authoring section referencing how to author with ifoedit:
https://www.videohelp.com/forum/userguides/120013.php -
Doesn't mydvd convert the audio from mpeg to pcm, and hence considerably increase the size of the audio stream. This would explain why it wont fit. Use an authoring program than can use mpeg audio.
my dvd is crap use tmpgenc to sperate the audio and video into m2v and mp2 files then author it with ifoedit finally burn with nero
Yeah mine never fit with MyDVD cuz of the audio conversion it does so I use MovieFactory by Ulead and havent had a problem....
wot i've been doing is using ulead DVDmovie Factory 2 and save it to hard drive does not matter wot size it is let it break it up into chapters
then use DVD2ONE with settings set to 3400MB redo it again then burn it works great for me
