Hey.
I'm capturing from my TV omposite in.
I try to capture with MP3 and PCM, and when I tried to use that in DVD2SVCD in order to convert it to MPEG2 format, I ran into sound problems...
On PCM BSweet stucks and on MP3 there is no sound.
From what I know, AVI's that has MP3-VBR sound codec (Whatever that is) are having no problems with DVD2SVCD...
Please help me know what codec to chose in order to use it with DVD2SVCD
Thanks, Amit.
Don't capture with mp3 if your going to run it through an encoder after.
Its best to use uncompressed sound for capture.
Then let the encoder change it to the correct format.
Fozzee
Which codec is the best for capturing VHS?
By aaxpers in forum Capturing and VCRReplies: 2Last Post: 27th Jun 2011, 07:45 -
Use a software codec when capturing with an ADVC300?
By timothyd_1975 in forum Capturing and VCRReplies: 22Last Post: 16th Jun 2009, 00:06 -
No sound on certain codec. Can I convert?
By ufcdanny in forum Video ConversionReplies: 3Last Post: 27th Jul 2008, 08:55 -
Best compression codec to use when capturing 720p video?
By Mysteriouskk in forum Capturing and VCRReplies: 3Last Post: 25th Nov 2007, 00:51 -
Which Codec is the Best for Capturing?
By rocknico100 in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 21:47
